95 toyota tacoma help
So, my toyota tacoma was really sluggish and had no power on pushing the gas and a few people told me it was a fuel delivery problem. I replaced the fuel pump didn't fix but helped, then got injectors at a junkyard and it also improved the power in my truck but no fix also tried replacing the fuel filter and ignition coil.
I ended up going back to the old coil because the new one was causing my truck to misfire badly and the exhaust to backfire pretty bad. A couple months ago i had a tune-up done spark plugs, new wire set, and cap. tried a knock sensor and tps without any luck. It starts up quick and idles good but just real weak unless you keep the rpms up and its mostly the middle of acceleration that is bogging if i floor it I can speed off.
I'm trying to avoid a big bill from a mechanic taking his sweet time finding the problem so if anyone knows i'd be appreciative.
Where are you located?
Clogged cat? Can you pull the front o2 and see if there is any improvement?
kind of sounds like my 03 tacoma. Sucks it doesn't throw a code. I've had a bad #1 o2 sensor that through a code years back and replaced it. I didn't notice any power problems but now i seem to be lossing power every now and then, but no code.
