94 LC coolant tempSensor location
Guys, I purchased the coolant temp
Sensor part 89422-35010. Two questions:
1. I wanted to purchase the coolant temp sensor that went to the computer not the temp
Gauge. Did I buy the right one?
2. If It is the right one, is it located near the oil filter or the other side by the thermostat?
Appteciate the help. Thanks, Hutch
Yes 89422-35010 is the correct part number, the gasket for it is 90430-12005. The location near the oil filter in the attached pic attached is a bit better than just describing it.
Anyone know if coolant sensors are the same for ECU and gage? I need one for gage. Thnx
Did you see post #3 above with the big, honking.....picture?
Yes!
Different part #s for ECU and gage sensors - looks like I need a 83420-16040
Yes!
Yep, just like it says in the text in the upper left corner. "Sender Gauge"
