Alright mud, I am posting this out of desperation. Long story short, I just swapped a 1FZ from a low mileage 93 in to my 94 and its not cranking. No click or anything from starter when turning key. The motor ran great in the parts truck I pulled it from and it cranked fine on the old motor as well.
Pulled starter and bench tested it and it works great. Cleaned contacts, terminals and mounting face (on starter and block) to make sure it was getting power and ground. If I run power straight to the solenoid on the starter it cranks the motor. But when I plug it in and turn the key... nada.
Tried starting in park and neutral to try and rule out the neutral safety switch. Tried starting while jiggling the key around in the ignition. Checked all fuses, connections to the ECU, made sure all the engine grounds were in place. I've had the battery on a charger to make sure its got a full charge and am getting 12.6 volts. The main fusible link was damaged so I just have the wires soldered together at the moment with no link in place (have a new one on the way).
Is there something I'm missing? Anything else I need to check? I've looked around on here and in FSM and not having any luck. I'm sure its something super simple that I'm forgetting but its driving me to the point of insanity. I just wanna drive my 80 again!
