For Sale '94 FZJ80 Upstate New York (Mahopac)
Photo Gallery (23 pics): 1994 Toyota Land Cruiser FZJ80
184k miles, runs very well
3" lift and many new parts, but a lot of things need fixing
A̶s̶k̶i̶n̶g̶ ̶$̶3̶2̶0̶0̶
A̶s̶k̶i̶n̶g̶ ̶$̶3̶0̶0̶0̶
A̶s̶k̶i̶n̶g̶ ̶$̶2̶8̶0̶0̶
A̶s̶k̶i̶n̶g̶ ̶$̶2̶6̶0̶0̶
Now asking $2300
Contact by PM or call me at 914-393-1258 any time on the weekend or between 7-10 pm EST on weekdays. No texting.
Edit: Price reduction, added trip photos to Montana to photo gallery, added detailed description of vehicle in next post.
Edit: Sold
More detailed description:
Replaced parts and service performed:
- O2 sensors – 2 years ago
- front end rebuilt: seals, bearings, birfields (work done by Prestige Toyota, Billings MT, In 2009) - about 65k miles ago
- starter – 2 years ago
- tie rods
- AC condenser (unit in front of the radiator)
- brakes and some lines – 1 year ago
- exhaust down tubes, weld on flanges, gaskets, muffler (Basal) – 1 year ago
- emergency brake assembly (OEM Toyota) – 6 months ago
- wires between transmission solenoids and computer (3 wires) were jumped, original were failing
- new Old Man Emu Nitrocharger shocks installed – 1 year ago
- new synthetic oil replaced in transmission, transfer case and differentials – 6 months ago
- tune-up done using all Toyota parts – 6 months ago
- tires reseated on rims and balanced – 1 year ago
Work Needed:
- AC high pressure line is leaking, rest of system is very good
- oil pressure sending unit electrical contacts broke off, new unit needed
- idle control module needs replacing or cleaning
- front and rear lockers stopped working, for a while they would only engage in rain, now not at all
- my mechanic claims that the rear axle housing will have to be replaced due to rusty bracket attached to it
- small bracket attaching front sway bar on the passenger side of the frame rusted out, that is why I took the bar off
- speedometer stops working after warming up, probably another failing wire in the harness, I have the wire identified and will try to bypass it
Exterior issues:
- rust spot under rear window
- rusty gash across both driver side doors (accidentally hit with snow plow, did it myself)
- dent on top of roof (I do not know how it got there)
- paint faded on hood, front of roof and passenger door, under window
- tires have about 65k on them, Firestone Destination MT’s 285-75-16, but should last another 10k
Interior issues:
- steering column cowl fell apart, have new cowl but not installed
- seams broken on driver’s chair seat, currently chairs have sheepskin covers
- some dashboard buttons lights stopped working after installation of CDF
- rear heater disconnected due to rusted out pipes above transmission
Spare parts included:
- tie rods assembly, used
- starter, used
- alternator, new
- front sway bar
Additional information:
- very reliable
- drives perfectly straight, doesn’t wallow
- Old Man Emu 3" lift
- driven in the Rockies, desert, and used as a recovery vehicle for my son’s Tacoma
- used as daily driver
- solid 11 MPG
- chassis and body rust as shown on pictures
- I am the 4th owner, first owner was Roger Clemens (MLB)
- sheepskin seat covers help when it is 120 degrees in the desert
- have third row seats
- engine is very good
- transmission is very good
- roof rack not included in sale
Price drop to $2600.
If no one shows interest in the next couple of weeks or so I'll take it off the market.
I seem to have lost the ability to edit my posts and cannot edit the OP or any other post. The previous post lists the current price ($2600).
I've learned that some people may have trouble viewing the photos posted in the original post. Please let me know if you guys are able to see the photos (regardless of your interest or lack thereof for this vehicle). Here's an alternative link to a Google Photos album with the same photos: https://goo.gl/photos/8ZCDAEFhXHch4koMA
Here are some of the photos in case the links don't work.
Since it's been a year that this ad's been up, here are some more updates on the condition:
-Newer stater installed 3 months ago, once in a while it won't turn over, and when that happens the key has to be turned on and off a few times before the engine finally cranks
-a few tire balancing weights fell off
-bottom of the driver side doors rusted a bit more
-speedometer wire was jumped but it didn't help the issue, so it probably needs a new sending unit
Here are more photos detailing the rust spots on the undercarriage:
Axle housing: https://goo.gl/photos/UpvuBrhqcPNmMHNz5
Front sway bar area: https://goo.gl/photos/jCTx5wct6PgRoEwh6
Other than that it still runs well and is a daily driver. Asking $2000.
@White Stripe I saw this when I read it earlier
"- front and rear lockers stopped working, for a while they would only engage in rain, now not at all"
2nd post on this thread under "Work Needed" :cheers:
