- Thread starter
- #21
I also pulled the EFI fuse this evening. Took it for a drive with a couple of stops to shutdown, restart.
No change.
No change.
You can adjust the idle my adjusting your idle cable (IDK what it's called, the one that doesn't move when the gas is pressed)
You could also run live data off an OBDII scanner
How did you “check” injectors. Flow rate balancing is a good idea if you went that far.Coming back to this in case it helps someone else.
This vehicle blew out the head gasket at the front of pot #1.
Finally got out all buttoned up and running lay night after revisiting the head gasket.
While it was apart, I checked all injectors. Changed ALL vacuum lines, replaced the harness connectors on all injectors (some where in poor shape), changed the rubber crossover pipe from air cleaner, changed the PCV grommet and hoses
So, I suspect for me, the head gasket was the problem, but potentially vacuum related.
Some hoses were past the use by date for sure. Could well have been a vacuum leak. I particularly suspect the PCV hose and grommet may have been leaking.
