Tarbe, are you observing behavior similar to mine now?
Yup. I have never been above horizontal, even crawling long hills at low speed. Usually 1 to 2 needles below.
Without going back through everything, do you think a modded '94 gauge would work in a '97?
-B-
it would work mechanically but iirc there is a screw mounting hole out of place.
Where are you?wearsabrowncoat said:Anyone have any extra resistors? I'd be willing to pay for parts and shipping. I'll order from the source if I have to but I hate paying inflated shipping costs.
Thevenin equivalents are not all that bad... it's no different than general relativity and the idea that gravity and accelerated motion are indistinguishable. I will admit though that Thevenin equivs are not quite so straight forward until you do some "hands on" with them.
Maybe it will be worthwhile for me to try and more accurately model the circuit -> needle position correlation... eventually I would love to script up something where different circuits can be "built" and a virtual gauge can be toyed with. I'm fairly confident I have the necessary math/calculus background to accurately describe all said circuits and the needle position, I suppose it would come down to the necessity of a predictable and fairly accurate needle solution from Toyota (read: no varying resistive-spring tensioning on the needle) as well as decent measurements of the components to describe everything mathematically.
It sounds to me like to 100+150 combo is a little too numb for a hot climate like Florida and the 50+110 combo is a little to sensitive. Hrm hrm hrm... decisions decisions.
I tried to be cool and bend the resistor over like your post shows, but I put mine on the inside, and when I pushed on it, the metal strip separated from the board, and I had to superglue it back on. So, be careful with the circuit board, and don't bother making it look pretty, not too many people will look in there.
Thanks again!
Dan
Thanks for posting up dash tips for the 93/94 trucks, I figured it would be different but did not have one around to add any notes.
you were suppose to bend the resistor legs before you put it in
m said:RavenTai said:m said:Raven,
You mentioned that 110 ohms resistor will get HOT. Just curious if you know if the original 75 ohms resistor would get HOT too. I am trying to find out if it is normal to get hot, or just a side effect of the mod.
Thanks
The temp sender is a thermistor who's resistance lowers as its temperature increases, so when reading high temperatures this reduces the overall resistance of the circuit and therefore increases current, the original 75 ohm resistor got "finger tip searing hot" when reading engine temps of 240 or so, the new 110 resistor is of a higher resistance therefore reducing current and it is also rated for a higher wattage (3w vs the 2w of the original)
So wile the 110 ohm does get hot when reading higher temperatures it does not get as hot as the original 75 ohm would have for the same engine temperature.
I hope that helps
If you don't mind i would like to post your question and my reply in the thread, if you are wondering about it probably so is someone else.
Raven,
Thanks for the reply. It helps! My main purpose is to find out if I need any special or extra cooling for the HOT resistor. I know the answer now since it is not going to be as hot as the old one.
No problem, go ahead to include my question in the thread. Please let me know if you want me to post the question so that you can reply.
Thanks again.
