- Thread starter
- #41
VS and THA are the VAF related ECM terminals.
There are four terminals shown on the VAF
-THA is the ECM terminal for the IAT.
-VS is the ECM terminal for the VAF itself.
-E2 is an ECM terminal. Can't tell if it is a ground or power but you measure voltage on the other terminals across this one.
Finally, rhere is another terminal on the VAF labelled VC that the FSM does not explain. It connects to the VCC terminal on the ECM which is a TPS terminal.
the FSM gives the following voltage for the VAF to terminal E2 which I assume is a ground.
VS at idle = 1.2 - 2.4 v
VS at 3000 rpm = 0.8 to 1.3
Also,
VS with ignition switch on
-measuring plate closed = 3.5 to 4.5v
-measuring plate fully open = 0.2 to 0.5v
THA is measured at 20 degrees celsius at 0.5-3.4v
I just did some testing on my VAF.
Interesting results.
Mapping of the connector (not vaf side showed)
Engine off, Key turned to on.
pin 1,2,3,4,blank,5,6 (seen as you look at the connector)
Pin 1; 5V
Pin 2; floating, as shown above, varies with air flow when engine on.
Pin 3; ground
Pin 4; 5V
blank
pin 5; 12V
pin 6; ground
I measured voltage across the 2nd pin in from the right as you look at the VAF (2nd from the left on the connector).
Warm Engine, parked, no load.
Voltage with Engine off 3.93V
Idling at 700RPM; 2V
2K RPM; 1.31V
3K RPM; 1.04V
4K RPM; .84V
My initial thoughts of all this is that we may have to adjust the conversion of the MAF to between 0 an 4V.
I'll take a look at how I might do this and adjust the circuit design.
I don't think a MAF uses the full 5 volt range either so you may not need to compensate. but you might need to slide the range to have the same
hmm. comparing the manual specs to your results it looks like your pin two is the VS circuit and is more or less exactly in the middle of allowable spec.
i'm not sure which the THA/ IAT pin is as volts don't line up.
