Wanted 93-94 fj/fzj80
Hello all,
I'm in search of a 93-94 Landcruiser. I'm willing to go as high as $5500, but I may be able to go a little more if it's worth it.
This will be a daily driver as well as a weekend warrior. I would be interested in properly modified trucks, but I'm not looking for anything too crazy since I will be using it as a daily driver.
I'd like to find one with factory lockers, but it's not a deal breaker. However, it must have the 3rd row seating option. I'm more concerned that it is mechanically sound. I'm not interested in dumping lots of money into a truck for basic mechanical repairs. However, I understand these trucks will have some miles on it and I will have to maintain it or fix/replace normal wear and tear stuff.
I live in the Olympia/Tacoma, Washington area. So anything in this area, the Seattle area, or Portland, OR area would be great.
Thanks!
I am in generally the same boat, but I have a question....
Why 93/94?
I was under the impression that the 1FZ was superior to the 3FE and that 96/97 was OBDII compliant instead of OBD1 or 1.5 and that was desired.
Is it price point?
Just want your take...
Sorry if this is a bit of a hijack
Why 93/94?
Is it price point?
'91 & '92 FJ80s have the 3FE, '93 n' up are the FZJ80 with the 1FZ till 100 series, take notes test on monday :cheers:
From Slee's website: (Slee - 80 Series Land Cruiser Newbie Guide)
1. MODELS
1.1 US models
The first model of the 80 Series imported to the US was the 1991 model. This model was sold until 1992. 1993 saw the introduction of the new 4.5 L motor. In 1995, the dash was updated to include airbags and this model ran until 1997, which was the last year of the 80 Series. Below is a list of major specifications and changes that were made.
1991-1992
First major wagon body re-design since the 1980 introduction of the 60
series.
3FE 4.0L engine and A440F automatic transmission held over from the 62 series wagons.
Introduction of full time, four wheel drive system.
Introduction of all coil suspension for the wagons.
15" x 7" alloy wheels standard and unique to '91-92 but the same as SR5 mini-truck wheels
front disk / rear drum brakes with FF front and SF rear axles
third row seats available for the first time
no airbags available
no ABS brake system available
no factory lockers available
1993-1994
Introduction of 16" wheels.
Rear axle changes to full floater with disk brakes when equipped with ABS
Also gets viscous coupling HF2AV transfer case versus
non-viscous HF2A transfer case for drum braked 80's (and fj80's)
Introduction of 4.5l 24 valve motor.
Front and Rear factory lockers become an option.
Automatic transmission - Electronic Controlled A442Fwith mechanical lockup converter
Somewhere in 1993 the AC system changed from R12 to R134. With the R12 systems the dryer unit was in front of the battery and with the R134 it moved to behind the bumper. Might have been in 1993
The thickness of the drive plates on the front hubs were increased after April 1994 (build date). The new drive flange number is 43421-60040 and the old one is 43421-60022. This is important since certain after-market birfield joints were based on the earlier birfield. If you try to install an earlier birfield into a later truck, you will not be able to install the circlip on the end of the axle shaft.
Supercharger systems now available for 1993-1994 models.
Front ABS Lines are routed on the front control arm.
Radiator is a 3 row brass core.
1995-1997
1996 saw the introduction of the Lexus LX450 Model.
Exhaust system changed from side by side catalytic converters to in-line converters. The exhaust also routes below the frame rail just behind the catalytic converters to avoid excessive heat on the passenger floor-boards.
Front grill changed from the word TOYOTA written across the front to the new Toyota symbol.
Headlight mounts are different from 1991-1994 vs. 1995-1997 and will not interchange.
Redesigned dash board with airbags as standard equipment.
Headliner changed to two piece molded units.
Emission system on engine changes. Changed from a Mass Air Pressure meter to a Mass Air Flow meter. Certain plumbing was also removed.
Supercharger & Turbo systems available for 1995-1997 models.
ECU updates and truck became voluntary OBD-II compatible. Fully compatible in 1996 models.
Wheel Lug nuts change from conical to washer type.
Airbags become standard
Automatic transmission changes to the A343F. Some 95's were produced with the A442F. The transmission type is printed on the label on the driver door.
1997 saw the introduction of the 40th Anniversary editions as well as the Collectors Series.
1997 the rear swaybar brackets that attach the bar to the frame were changed from a plate side that attached to the side of the frame to a bracket style that attached to the bottom of the frame.
ABS wires on the front were moved upward and no longer run down the front control arm.
Radiator is a 2 row aluminum
40th Anniversary Specifications
Two Tone leather seats
Serialized symbol on center console.
40th Anniversary floor mats
40th Anniversary emblems
Black Chrome badging
Available in Sage and Green colors only
Auto climate control
Lexus LX450 Differences
Revised Audio System with sub-woofer in the center console.
Optional factory installed cell phone.
Softer suspension.
Body cladding on doors, fenders and tailgate.
Rear bumper corner pieces are bigger and the rear cross member is coverer with a plastic trim piece. Mud flaps are two-tone colored and not interchangeable with an Toyota
Auto Climate Control
Softer leather on seats and additional sound proofing.
Yeah, thanks for the hijack, I mean bump :p. I am mostly interested in the 93-94 because of the price point and from what others have mentioned above, some pretty good improvements were made in 93 over the 91-92. I'm also hoping to find the factory lockers. I hope I'm not asking for too much in this price range.
I did learn the difference between the FJ80 and FZJ80 though. I've been trying to figure it out. So, thanks for mentioning it.
So, if anyone has a 93-94 FZJ80 in the greater Seattle/Portland area, shoot me a line. I'm seriously searching. Also, if you have an earlier model that is in my price range, let me know.
Thanks,
Russ
There is a party that has 94 w/factory lockers and 158k on the clock that was in line to acquire my 60 over in my For Sale thread...They are going to sell outright and they are in your price range. Its a good truck from what I can tell of the pics. I would buy it but have found something totally different and unexpected that I'm interested in.
I have Pm'ed you and told her to contact you as well. (She's on Mud)
