- Location
- United States
1992 Toyota Land Cruiser FJ80 3FE/Auto 167,228 miles
We started with the drivetrain. We completely removed both front and rear axles, disassembled them, stripped to bare metal, cleaned and painted them. We installed new 4:88 gears and ARB air lockers in the front and rear differentials. Reassembled the axles with the newly rebuilt 3rd members, new gaskets, seals, bearings, RCV chromoly front axle shafts (bullet proof!), rotors, calipers, pads, wheel cylinders, shoes and drums. New tie rod ends installed. At the same time, a 3” OME suspension lift with front spacers (to level the stance)was installed, new extended brake lines, sway bar extended links, new bushings in all the control arms, links and sway bars. 5 new BFG KO2 AT tires were installed and OE rims painted. We installed a new spare tire carrier that has a new high lift jack attached to it. An OBA (on board air) system was installed with a 2.5 gallon tank where the original spare tire was. The front windshield was replaced along with a new OEM seal. Drivers front door and tailgate had a few dents so they were repaired & repainted. The rest of the body is clean. There’s some scratches and small dings, but no rust! Trans fluid and filter was changed.
Recap for ease of reading:
Rebuild front and rear axles.
-Stripped and painted.
-New 4:88 gears.
-New ARB lockers.
-New bearings (differential, knuckle and axle).
-New gaskets & seals (OEM)
-New RCV chromoly front axle shafts.
-New Rotors, calipers and pads (front).
-New drums, wheel cylinder and shoes (rear)
All new tie-rod ends installed and steering rods stripped and painted.
3” OME suspension system:
-Front and rear coils.
-Front and rear shocks.
-Steering dampener.
-Castor correction bushings.
-Front and rear extended sway bar links
-Extended brake lines.
-Front spacers
All new OEM bushings and hardware:
-Control arms.
-Front pan hard rod.
-Rear upper and lower links.
-Rear pan hard rod.
OBA system with ARB twin compressor and 2 ½ gallon tank. Front and rear air connections.
5 new BFG AT KO2 tires on OEM painted rims.
Swing-out spare tire carrier w/new high lift jack.
New front windshield with OEM seal.
Dents repaired in drivers front door and tailgate and repainted.
Transmission filter and fluid changed.
More pics:
Vehicles for Sale |
SOLD
-New 4:88 gears.
-New ARB lockers.
-Steering dampener.
-Front spacers
-Control arms.
-Rear pan hard rod.
More pics:
Vehicles for Sale |
SOLD
