90k Service Time
ntsaint
Don't Assume I Know The Basics...
Louisiana
It's time for my 90k service..actually past time, I'm at 96k.
I've spent the past few days combing though every 90k thread I could find, trying to make up a current list of items that need to be addressed.
I'm going for the large list, because I'm going to do my best to put 250k on this truck. I love it.
That being said, here's my list. Obviously a couple of these I will do myself (PCV, Air Filter, etc):
Replace Timing Belt / Tensioner Pulley / Idler Pulleys
Replace Drive (serpentine) Belt / Tensioner
Replace PCV Valve
Replace Water Pump, including O-Rings
Replace Thermostat, including O-Rings
Replace Camshaft seals
Replace Crankshaft seal
Full lube
Flush front, rear, and center differentials
Flush Transfer Case
Flush Coolant
Flush Power Steering
Air Filter
So, my question is, what am I missing? What is overkill, if anything?
I've gotten CDAN to price all the parts (around $500) and my dealership is quoting around $900-$1000 in labor. Total of around $1500 parts and labor, which doesn't sound too bad.
Any input would be welcomed...
I think you have it covered.
bkgee said:
these are the same unit. you might also add some sort of transmission and breaking system PM to your list. :cheers:
Yes they are...thanks.
Sent from my iPhone using IH8MUD
I JUST rolled over 90,000 myself. Dealer quoted me $995 parts and labor for what THEY think is a 90K service. How much of what they do falls short of you guys think should be done? I might have to ask who this CDAN is for my own part list.
this was brought up 2 weeks ago, Beno has a list in this thread.there is also some pricing for parts. parts adding up to $450 plus or minus.
https://forum.ih8mud.com/100-series-cruisers/543769-does-900-00-sound-about-right.html
Piling on to this thread with my own question: in addition to all the standard 90K stuff, are there addition maintenance items to consider? I was thinking the radiator too, but didn't purchase.
I did purchased the following from Onur:
1 13568-09070 BELT, TIMIM
2 16100-09201 PUMP ASSY,W
3 90916-03100 THERMOSTAT
4 16346-50010 GASKET, THE
5 13503-0F010 IDLER SUB-A
6 13505-0F010 IDLER SUB-A
7 13540-50030 TENSIONER A
8 12204-50020 VALVE SUB-A
9 90480-18001 GROMMET
10 90311-A0001 SEAL, TYPE
11 16571-50150 HOSE, RADIA
12 16572-50150 HOSE, RADIA
13 00295-00103 FIPG OIL PA
14 16401-67150 CAP SUB-ASS
15 90916-02586 BELT, V-RIB
16 23300-69045 FILTER ASSY
Might be a good time to do heater T's if that's not on your list, since you'll be draining coolant anyway. And of course brake fluid and AHC fluid (if equipped) is due every 30k. Maybe power steering fluid since you are doing nearly everything else at the same time.
Looking at my list, I wonder if you might want to add in spark plugs and heater hose T's? And I assume the wheel bearings/spindle bearings on yours are up to date on lube.
Oil filter 90915-YZZD3
Air filter 17801-50040
Gas filter 23300-50090
Cabin filters 88568-60010 (2)
Hood struts 53450-69026 (2)
Spark plugs 90080-91180 (8)
Timing belt 13568-09070
Serpentine belt 90916-02585
Water pump 16100-09201
Idler pulley 13503-0F010
Idler pulley 13505-0F010
Tensioner (T-belt) 13540-50030
Tensioner (serp belt) 16620-0W101
Thermostat 90916-03100
Thermostat gasket 16346-50010
Housing O-ring 96761-24019
Fan bracket 16307-0F010
Serpentine belt idler 16604-0F010
Upper radiator hose 16571-50150
Lower radiator hose 16572-50150
Heater hose T fittings 87248-60460 (2)
Trans pan bolt gasket 35178-30010
Shocks -front 48511-69625 (2)
Shocks-rear 48531-69835 (2)
Brake pads-front 04465-60230
Brake pads-rear 04466-60070
Brake caliper-front left 477306009084
Brake caliper-front right 477506009084
Axle shaft snap rings 90520-31005 (2 of correct thickness)
Front hub flange gasket 43422-60070 (2)
Front hub lock washers 90215-42025 (2)
Front hub claw washers 90214-42030 (2)
Front hub flange nuts 43521-60011 (2)
Front hub grease seals 90311-70011 (2)
Wiper blades
Thanks - did the heater Ts a while ago and thought I did get the plugs but apparently Onur and I miscommunicated.
