I probably should have asked this BEFORE doing off my 07 LC for the second 90,000 mile service, at 193,653 miles, but...
What has been the cost you have paid, at the dealership or other service center, for the 90,000 mile service?
I was quoted $1,075 plus tax for:
Timing belt
Drive belt
Water pump
Seals
Cabin air filter
Engine air filter
I got him to take $110 of that price since I can easily do the cabin and engine air filters for $28 in parts. Do I'll be out the four for ~$1,044.
After reading the FAQ linked threads on timing belt replacement I knew that job was not for me because of my lack of free time and expertise with such a complex and "high cost of failure" service. Also, since it's such a critical component and potential engine killer I don't really trust any one other than the dealer.
I plan to save my nickels and dimes over the life of the LC doing the easy 1-2 [banana] maintenance and repairs. This week I saved money by doing the drive line lubrication of the propeller shafts and spiders, rear differential drain and fill, transfer case drain and fill, and will do the front differential drain and fill next week. I'm also considering doing a transmission fluid drain and fill since I found a drain plug in the fluid pan (when I read the relevant section if the 2004 FSM the diagram never actually showed a drain plug, only a fill plug and an overflow, so I was not sure if there was a drain plug until I crawled under the truck for the first time last night.). I'll do brakes, maybe I'll tackle a suspension component or lift, in the next year I'll possibly try my hand at mounting am aftermarket bumper or two, but a timing belt, seems just too risky for me personally.
Would you or have you allowed a non-dealer to do this service?
Thanks for your info and opinions.
Timing belt
Drive belt
Water pump
Seals
Cabin air filter
Engine air filter
