So I purchased my 86 this weekend and it won't go into Nuetral or 4LO on the transfer case. It will hit 4hi but not 4lo. Any Ideas? And I will get pictures of it up eventually. Gotta wax it to fully show off the rust.
Are you saying that it if you crawl under the truck and try to push the shift lever into neutral or 4 low it won't go? Does the lever move? If the shift lever moves but the truck does not shift, then the problem may be that the high and low inner lever has slipped down and is not engaged with the shift fork.
If this is the problem you might be able to loosen the clamp and pull up on the shift lever to engage the slot in the shift fork, but don't drop the lever into the transfer case.
this seems to work for as well!Try engageing it after you put it in reverse and back the cruiser up abit. Mike
maybe you linkage is all f*cked upthis seems to work for as well!
this exploded view
You would be totally lost without your "EXPLODED VIEWS"
2mbb my have same problem on 4Lo too and I drop inner lever and I have hard time to get back?
Well I got it last night...had to stand on passenger side and pull it like a mofo. Got it to move.
