For Sale 85 FJ60 2F parts in Phoenix, AZ
Did you part out the 2F engine? (will you?) :)
Have some things available....Get it while it's HOT!!
Summertime Specials!! PM me for photos...
WHAT IS LEFT :
BRAND NEW 2F/3F Distributor (Toyota- in box)---$240
Toyota Power Steering Pump- ready for rebuild----$55
Toyota Power Steering Reservoir--no cap--$25
Toyota Fan Clutch--Works----$20
Aisin Water Pump--w/cooler--Works---$25
Oil Cooler hard pipe---Great shape--$20
New HEI Distributor with NEW "Livewires" performance plug wires in Box)---$310
FJ60 Spare Tire Carrier--Works great...smooth, little dirty----$35
Used (SOR) Suspension Skid plates---$50 Front/ $50 Back
Rear washer bag and pump--works great, no leaks--$15
(SOR)-3 way Tube---(vacuum system) metal--$5
FJ60 2F Carburetor--- ready for rebuild- all in tact---$220
Newer SOR shackle bolts/nuts/washers/ & four 3" Lifts (slightly bent)---$30
Four (4) Original Shackle Centering pins--threads are good--$10
Water temp sending unit--used--works--$5
NEW-(SOR) Rear stabilizer bar links--in Bag--$20
Used original Toyota Rear Stabilizer bar links--need new bushings--$15
Rear seat bottom fabric & 1 Front/top seat Fabric---both Blue/Grey --great shape--$35
Pair of Hood springs--$10
Front and Rear -(R & L) Original Spring Seats --Front Pair $40 /Rear Pair $40
WHAT IS LEFT :
BUMP
BUMP---
Great Parts Available!!! Check it out!
Rear washer bag and pump--works great, no leaks--$10
BUMP...
parts still available!
Just checking to see if you by chance have any 3.70:1 diff gears? Trying to find a pair for someone in Australia I can pick up and ship over.
BUMP---get some good stuff before the summer is over!!
WHAT IS LEFT for SALE:
BRAND NEW 2F/3F Distributor (Toyota- in box)---$200
Power Steering Pump-may leak a little, not sure, ready for rebuild----$50
Power Steering Reservoir--no cap--$20
Fan Clutch--Works----$25
Water Pipe-hard---great shape--$20
Water Pump--w/cooler--Works---$35
Starter---Works---$50***SOLD****
AC Compressor--not tested--$40
BRAND NEW HEI Distributor with NEW "Livewires" performance plug wires in Box)---$275
Original Spare Tire Carrier--Works great...smooth, little dirty----$40
FJ60 2F Carburetor--- ready for rebuild- all in tact---$200
New SOR shackle bolts/nuts/washers---$20
Four (4) Original Centering pins--threads are good--$30
Rear seat bottom fabric & 1 Front/top seat Fabric---both Blue/Grey --great shape--$25
Hood springs--$10
WHAT HAS SOLD & PRICE:
Original working HI/LO horn set--$30***SOLD****
Coil--Works--$30 ***SOLD****
Fan Blade---Great Shape, no cracks---$20**SOLD**
Original FJ60 mirrors--great shape---$50 **SOLD**
Fuel Filter--NEW--SOR----$5**SOLD**
Fuel pump insulator--New--Toyota--$5 **SOLD****
Exhaust Manifold Gasket--New--Toyota--$5**SOLD**
Air cleaner intake hose--no holes, cut at end--$25***SOLD***
Headlight washer pump--works--$15**SOLD***
NEW Toyota FJ 40 Radiator Union Pipe--$20--SOLD*****
Hose for Air intake to exhaust manifold heat shield--good shape--$5***SOLD***
NEW in bag oil sending unit--$40---SOLD*****
New in bag (SOR)Battery disconnect kit--$5***SOLD***
Box of several seatbelts and misc seatbelt parts---$40***SOLD***
NEW--Catalytic converter removal pipe... with Flanges--$20---SOLD****
is the seat fabric the part that goes in the he bottom side or is it the upholstery you sit on? any stains or tears?
interested in that and the skid plates. when can we meet up?
