So i did a little more reading on WVO and some think it can harm you engine over time. The on story I read about a TDI Jetta looked bad.
I'd be willing to bet they were running bad oil, or not running it at the proper temps. I have a friend with a Jetta TDI, who has been running as long as I have. We both switched over within a few weeks of each other. He has had no problems at all. Proper filtering to get the water out (verify with a Hot Pan Test), only run it at temp, always purge and you'll be fine. It's very easy to get careless and run crap oil - that will kill your engine.
Maybe I should and read through John Galts many pages but I do not have the time.
So my question is about the acidity, is thier a way to test and adjust?
Hmmm.. Yes, you should read his pages. As much as he can be a bit of a dinkus, he knows some good sheet. I don't test for acidity - I'm sure I should - I'll probably kill my engine(s)/injectors/pumps but I have had great luck so far.
I used the goldenrod for prefiltering out of a container. It did not take long to plug.
Hmm, you were probably doing it cold weren't you? Filters clog very quicly with cold oil. My pre-filter setup I filter the oil through the goldenrod at about 40°C. I also heat cycle the oil a few times (24hour period to cool) for a week before I filter it. I do this in a 55Gallon steel drum that is insulated and has an electric heater element in it. This allows a lot of the free water to precipitate out to the bottom - where it sits (I suck the oil from above the bottom) I should also mention, that this oil has already passed through 600,400,200 & 100 micron filters, and usually sits in the sun for a few months before this process begins...
Doing wvo can be messy so be forwarned.
Hells yeah! CAN be? Until you get a good system, it WILL be! (and can still be!) I have most of my filtering setup done through piping and pumps, so I rarely have spills now - but folks starting out need to be prepared for a mess!!
IF you made another tank, what would you charge for it?
Well, it's tough to say - I wouldn't make another one like that, I'd make one like the one I just made, but even not quite like that! My new tank is 9" high, fully insulated and a little different (some R&D component involved in it for work). Bottom line, if I was to make another tank, it would be low, wide and as big as you can stand!
Now, I had to rebuild all my injectors. I cannot for cirtain say that the wvo had anything to do with its wear paterns. But over a 6-12 month period, noticed a degradation of the injector seats.
I pulled my injectors after a year, and they were almost perfect. No signs of wear at all. I swapped in a different set and there was absolutely no change in performance. I think I can safely say that the oil I am burning, in the way I am burning it is not causing damage to my engine. I have done about 20K km with veggie with no obvious ill effects. (not saying there is nothing, just saying I don't see anything) I only run when the engine is up to temp, and I always purge. I only ever run oil that I have fully processed - and I don't take shortcuts in my processing.
What did you use for a fuel sender? Another stock land cruiser fuel sender ?
First tank was just a Princess Auto fuel sender, I think it was about $10 - same with the gauge. Second tank I used a WEMA marine fuel sender - much nicer - but still bounces around quite a bit. WEMA sender was about $60. Not sure if I'd go for the difference again...
i really want your notfox.
i might have to weld one up myself.
hows the system running for you?
anything you would change?
Yeah, the notfox is pretty popular! So far I have made 3 and a friend has made 1. More to come as tanks are changing, and more vehilces on the list to be converted. (my wife has a BJ70 and I have a Case 580 backhoe to convert!)
Changes... I'd like to add a second valve to allow for quicker purges... It's more complicated, but it would bypass the stock filter when running veggie - and thus reduce the quantity of diesel required to purge out the veggie. 3 minutes isn't bad, but compared to the 8 seconds my ford takes.... it drops the efficiency quite a bit!
Other than that... the system has been pretty bullet proof. Ran great all winter, no problems coming up to temp, no purge problems... Happy camper!
New tank - aluminum, around 110L, insulated, better filling, vented to the filler neck, with sight tube (much easier filling!)
And best of all, it's now hidden under this! :
Which means I can sleep in the back now!
