The torque rod is the one that lives between a hanger at the top of the firewall and the carb base bracket. It should be installed so the short arm is receiving the push up from the gas pedal and the long arm is applying push to the carburetor.
Clear like mud, yes?![]()
You have a point. The inclines are milder here, to be sure. My point of reference remains what I was experiencing before we flipped the torque rod. Secondly, I just finished a road trip from Jackson to Flagstaff, AZ (I'm from AZ). We made multiple climbs heading across New Mexico and into AZ. The truck was carrying four guys and was overloaded with gear and mountain bikes dangling from the rear. In this state it wasn't doing 70 up hills, but I don't ever recall it being a sluggish turd either. My 2f now has 160k and is in good tune and condition. I was rather surprised at how well it did, considering how much I've heard to the contrary. How to explain this? I find myself in agreement with Doug Grahams sentiments. It doesn't appear that 60s are supposed to "creep" uphill.
bh
I'm thinking about buying a 82 fj60. however, when you drive up hill it looses power. it doesn't cut out, it still runs but it just creeps along. the owner says 2 different mechanics have looked at it, and can't find anything wrong. any ideas?
thanks
The cool thing about this is, this acts as a governor for when my teenager drives it. Perfect!
That's because it's a FJ60, and it only has 125 horsepower (new from the factory) and it's pulling about 5000 pounds.![]()
my '87 250,000 mi+ original engine31" tire and 4:10, can do 65-70 mph up on a grapevine,ca.
dorcom said:Also check if your second stage does open! The diaphragm activated 2nd stage is defunct if the diaphragm is torn. Also check your ignition timing and advance and double check on the HAC valve hosing as well as all other vac hosing.
This thread is REALLY old, but I must say - this post saved me a ton of headaches! Thank you!
But this torque rod fix was a proud moment in finding the joy cruisin'. For those of us that may have been unfamiliar with this linkage between the firewall and the carb. Here is a pic I snapped when I did the exhaust manifold gasket. Repeating which way to install...make sure that the long arm is closest to the carb, and that the short arm is at the firewall. Torque rod out... and then installed
