80 series power steering rebuild or??
Scottsdale Arizona
Ok the 93 (while we are replacing front end parts) the power steering box is leaking would you have someone rebuild it or just replace it?? Which way would you got and where?
Kyle
The seal kit for that is less than 10 dollars on rock auto. It is a fairly easy repair to do at home
That, I’ve been using the gates kits for years with no leaks. I have used the Toyota kits too, if I remember both use the same nok seals. I don’t replace the Teflon rings unless they are damaged. Same deal on pumps, and I use gates hoses as well. Costs about $100 for a full ps system reseal and new hoses from rock auto.
