I thought I would write this post because there were a few questions that did not get answered in my search to install a CB. There is a lot of great information out there though. For example the following Post by Beno with the link to the Tech article on Slee’s site:
https://forum.ih8mud.com/showthread.php?t=40474
The first question is what size CB to buy. I first bought a regular size CB like the one in my FJ40. I then came home and did a search after thinking about where to install it. Unless you have replaced your radio, there is no great solution to installing a regular size CB in an 80/LX450. That’s were I was pointed to the solution above that works great for others. I did something similar. So why did I feel this deserved another thread? The CB cable routing and power. I will include some solutions mentioned by others along with what I did. The thread recommended a mini Uniden. I searched around and went to a truck stop and they were out of the Uniden’s, but had a Cobra that was a little taller, but installed just as easy.
The next decision is routing the CB cable. The easiest solution was not obvious to me at first. (This is the part Beer is involved- Standing, drinking and looking)
Convert had the following suggestion:
I took off the Glove Box door and on my 97 LX450, there were to many components in the way to be able to get the access Dan Talked about. There were several other suggestions but I wanted to make sure I could get to it from the Dash side before I tried. Having the Glove Box off does help the install.
I felt up behind the dash above the Glove box and could feel a grommet. I went and looked in the engine bay and there was a grommet with what I would call two “nipples” on it. I cut one of the nipples and made the hole larger and placed the antenna cable through the hole. With the Glove Box off, I routed the cable up and over the radio and down to the ashtray slot. I then connected the other end to my ARB.
I took all the slack out of the cable from the engine compartment. I did not want it coming loose and catching on anything. I wrapped the excess in a loop and used a plastic tie and placed the excess in a spot to the left of the Glove Box.
convert said:Ken
If you remove the glove box door you can see wear the antenna cable comes thru the firewall . Then use a stiff wire to pull the cable through from the engine compartment to the cab. On My 93 LC there were only s couplle of screws to remove the glove box door ?? I had no luck with power at the console and gave up after talking to BVB . Hope this helps
