Left Grass Valley this morning after visiting family and rolled into Ely this afternoon. Little rain along the way but a beautiful drive.
Wait Grass Valley ca? We left there yesterday
[edit]
I see Grego posted same thing while I was typing.
Anyhow I would put off the dealer service, put a new filter on (get a Toyota one at dealer). As previous poster said, there is not oil in hoses going to oil cooler those are coolant lines. Oil comes through passages in block to and from cooler.
[edit]
If you recently changed filter, that would be first thing to pull and check. Could have nick on mating surface, bad gasket, etc. Get a new one.
That one does not look like a Toyota filter, they may have given you the wrong one, close but not quite right.
Pulled into Amarillo for the night.
Just before we got here, I looked and saw my AHC light was showing I was in low mode...and I was doing 70-80 mph! I freaked, slowed down and pulled off on the next exit. I stopped, got out and walked around the truck. It looked like it's on neutral, in fact it is.
But I stuck the flashlight down on the AHC reservoir and it is sitting at the minimum line. Turns out what I thought was the fluid line was a stain on the plastic of the reservoir. I'm dumb for not double checking this. I think it's the reason the truck won't go into high. Does that sound correct to you guys?
Also, anyone know where a guy can get some fluid on a Sunday....in Amarillo or in between here and Durango?
I'm blaming this on the Toyota place that "fixed" my problems not too long ago since my cap was missing when I got it back. So I have some foil and zip tie for a cap now!
I'll chuck the antenna analyser in the car; if anyone is curious to sweep their antenna just find me at some point.
Same, I can barely get 1/2 mile on mineI'll take you up on that! I have horrible range.
Yep that is my route. I should have posted earlier, as you have all kinds of great suggestions! Skyline red may not work as we are towing a 13 ft travel trailer. Googling black canyon now.
Shiprock? To stay overnight or see the sights? Don't get your hopes up.
Don't expect much more than that from a CB. They have a very low transmit power and if anything is in the way like trees or dirt, it's even worse.Same, I can barely get 1/2 mile on mine
