nuclearbeef
Here's the situation:
Front disks, rear drums.
Went through the rear drums when I bought the pig, improving the braking dramatically, but...
Since then, sticking your foot to the floor gets you about 60% brakes.
Let it up and the pedal is firm about 1/2 way down and stays there. Great brakes.
I just lived with it. pumped the brakes if I needed to stop quick.
So I just replaced both front calipers because I found a stuck pot on the right side.
Vacuum bled the fronts until nice clean fluid exited the bleeder. Still soft pedal on first pump.
Bled multiple times by pumping up the brakes. No improvement.
It acts like there is air in the lines. 2 separate fluid reservoirs, so even if the rear system was disconnected, I should get firm pedal and good front brakes.
Could it be bad rubber section of the lines???
They are old, but no leaks or bulges or outward signs of failure.
I'm stumped.
JW
I'm stumped.
JW
