My blast Cabinet saga
Mods:
built and sealed with silicone caulk
added double gang box with light switch and 2 outlets to plug compressor into cabinet and control internal lighting
added led lights in all corners of cabinet
added metering valve at bottom for constant feed (metering valve the home depot brass pipe fittings type.)
7/8th clear hose for sand feed
added 3/8 hose and regulator with direct connection from gun all the way to main quick connect at compressor
used all high flow 3/8 quick connects
added water extractor at compressor
Built a cart to easy mobility and it makes the glove height perfect for standing there for 3 hours.
swapped out gun for eastwood. changed all hoses to 3/8 high flow for eastwood gun and pedal. had to disassemble pedal as it had skinny ass clear hose to it.
I use a craftsman 33gal 2hp compressor with a belt pulley driven piston assembly. runs at 8cfm.
I run the gun at 40psi, melts paint and rust. I think it took 12 minutes to blast the entire air cleaner cover
some pics, I will take some in the morning of the gun and pedal connection.
