For Sale 72 Fj40 Sheetmetal - Firewall
kevos37
Supporting Vendor
Sutter, California
Update- I have the firewall left for sale. Rear floor sold and the passenger floor is pending. Fenders and apron are spoken for. I will start disassembly on the frame and motor next, if you are interested in anything let me know.
Kevin
Tub doesn't look shot to me. That would need some re-skinning, but far from gone around my neck of the woods. The cowl hack is the only thing really killing the condition. Everything else it needs can be purchased as a patch panel and welded in.
Unfortunately the previous owner just cut open the body to access the upper door hinges to remove them. sigh......
Some people should not be allowed around tools.
All in all that would still be a decent 3/4 tub. As long as the floors are good everything else is pretty straight forward to replace and readily available in aftermarket. I'd cut the tub at the rocker and put it on CL for local pickup.
The Driver side floor is missing too. I have seen a few tubs sit around on craigslist. I had advertised a rear tub on craigslist a while back, nothing. But...I put it on Mud and sold it. The shipping was not bad , $150 to the east coast thru Fastenal.
Here are some good pieces. Have yet to pull out the firewall.
I know this might sound like an odd request but if your cutting out pieces, I need the glove box section. A mouse took up residence in mine and its urine completely corroded the area where the speaker was. There was a giant nest in there and the sheet metal significantly affected. If that is something you can help me with, let me know. I'll shoot you a quick PM as well.
Posting the firewall pictures.
Is the steering wheel available, I'd also be interested in the bed rail, mine rusted out where the hard top sits on the body
The steering wheel is available, but it is really really really baked. It is cracked in several place and the hub has separated. I can send you a picture if you want, I will send you pictures of the rails.tomorrow.
Kevin
Are parts of the rear available? I need the top part of the rear corner. Maybe the rear corners them selfs too.
The only corner part that made it was the very bottom on the drivers side, about 3 inches up from the bottom. I'll send a picture tomirrow..
Kevin
PM'ed all previous questions/requests.
Last Call on complete firewall. Going to section off the right panel. Rear floor is still available,, has rust over the rear cell, ( fixable) but it is solid. Has the side tabs also.
There's a small spring under the washers on the steering wheel. Would it be available?
That unit was spoken for. I may have another, but its the whole washer with the spring attached. $25 plus shipping
