70 Series Recovery Point
Gun Runner 5
ODD IRON OFF ROAD
Thomasville, GA
**THIS RECOVERY POINT IS ONLY DESIGNED TO WORK WITH A 70 SERIES THAT HAS AN ARB BRUSHBAR**
Odd Iron Off Road has fabricated a heavy duty recovery point for the 70 Series + ARB brushbar. The recovery point is specifically designed to work with the ARB and high lift jack. Additional information is available on the website. ...... Thanks
This recovery point was designed to improve your ARB brand front bumper by allowing you to have a solid strong point of attachment for recovery. No modification to your bumper or truck, with or without factory PTO winch. A unique slot allows for use of a "high lift" jack and adds more stability to the jack placement. Made of 3/8 in. and 1/2 in. plate steel. Comes with new 12mm 10.9 grade bolts and instructions. Allow 7 to 14 days build time.
I have had these on two 70 series now with my original set an early prototype. These are quality pieces that are stout!
Thanks for the orders .... Your business is appreciated. :cheers:
The shop is starting to get orders for recovery points that are compatible with the factory bumper instead of the ARB unit. Unfortunately the existing version shares virtually no parts with the new design and therefore would require the new design to be fabricated from scratch. Having said that, the shop has started the preliminary steps to design such a recovery point.
Hopefully they can offer something later this Summer or by early Fall.
Thanks
Because it's somewhat difficult to match an email address to a 'MUD handle, I'd like to make a blanket statement of thanks to those who have ordered Odd Iron's recovery points. Your business is greatly appreciated. :cheers:
There is also a version that works with the TJM brushbar.
With the ARB compatible recovery points, the securing bolts run from top to bottom while the TJM bolts run side to side.
Both versions secure to the frame with multiple bolts.
The "cats meow" of recovery points. * :)
* These recovery points are ONLY compatible with an ARB brushbar and certain TJM brushbars.
Got mine installed! If you have a 70 and an ARB bar you need these in your life!
..... and thanks for the endorsement of Rob's products. :)
Finally a recovery point for the guys that have OEM bumpers on their 70 Series.
