'69 FJ55 plus a load of parts
:)Jim was kind enough to deliver the pig to me today...... really nice guy.:cheers:
Check out the hood orny:)
Is it me, or is that the most original Pig I have seen?
Did you find cargo glass for this?
What overall shape is it in?
I can't wait for detailed shots of interior and underside and engine bay...
Found cargo and rear glass. It's in pretty good shape. It does have an older Chevy conversion in it. A wierd chevy trany/trnsfr set up also. They got the column shift to work with a Chevy auto trans.....coming out for sure. I do have a 4spd setup I got from a 75 that I can put in it. As for now I have it parked in my shop's yard under a tarp waiting for the day that my current and long time pig get back on the road. Then I will start the transformation........
Pat...sorry, I don't. The body donor for my project had the tranny/transfer hump missing and I had to use the one off the chassis/running gear donor. No extras.
Have you looked at the hump in the the '69? Given the column shift for the transmission and the stock dash transfer case linkage, the only extra hole is for the oddball GM tcase. A little welding and body work and you'd have a clean hump with no holes to then modify however you want. You could deal with the '69 hump situation down the road when you're doing that project and would have to do something to revert to a stock linkage/hump situation at that time anyway.
Just a thought...
Jim
