1969 FJ40 (early). 3 on the column – dash button actuated transfer – under dash lever for transfer gears = No sticks or holes on the floor. Hard top with (w) doors all parts & glass – rear split tailgate w lift up glass / bikini top & soft doors / all 5 hub caps / 4 stock rims & 4 10X15 aluminums (needs ½ spacer or mod. frnt. ball joint to fit front). Original engine needs re-ring, engine apart, head checks good. Rancho shocks / front seat reupholstered in boat canvas & vinyl / roll cage / powerful older CB radio
Toyota OEM New Parts = Front parking light assemblies / front turn signal lens / clutch master & slave cylinders / drivers side mirror /
New parts SOR = Performance shackles w greasable pins / frnt. Extreme U-bolt skid plates / poly bushings / U-bolts / shim wedges /steering stabilizer (stock mount) / 1 stock rim / 2-pc. 3 into 1 headers w collector / dash restoration cover / passenger grab bar w pad / rubber diamond plate for running boards /
New parts =Ironman leave springs / Ironman shocks / steering stabilizer Rancho aux. mount / 2 – BFG 33-10.5-15 Baja’s / alum. Diamond plate rear fender covers /
