Wanted 67 Fj40 dash piece
Santa Rosa, CA
Looking for a portion of a dash of complete dash that I can cut a piece out of to patch mine. This is a 67 Fj40 but I believe almost all years have same dash looks.
No not all years have the same dash look, yours is the early style and may be the last year for it. My 68 has a smooth dash. Why not get creative and tack in a backer plate and then use a thin layer of “bondo” to fill in the slight depression. If you use tiger hair fiberglass bondo” you may even be able to create the lower “raised” area
I think I have most of that. I believe mine it cut to the left of that area. Can you measure the piece? Just how long the cut out is.
Yes I will measure it. If it’s larger than my cut out that’s fine i can cut it to fit. It’s length is 7.25” and height is 2.125 minus the area where the hole cutout is.
My parts dash has been cut too. The side that has been cut has been folded over about an inch. As you can see its a bit short. Your call. If you want to try and make it work. How about 20.00 for my time to cut it out and cover shipping.
Yours would be the same as a '64 it has the ribs also I pm'd you so it is yours if you want it.
