So my beast has a strange issue I cant hunt down. When it is hot out and the truck has been running a long while at slow speed or parked it will eventually start to fluctuate idle going up and down then it dies. It will start right back up but will die again. It will continue to do this until it sets for a while and cools down. The check engine light will com on somtimes but leave no code in the system. The cooling fan works fine when the motor is shut off. I dont know if it comes on when running as I cant hear it and when this happens the fan cuts on as soon as the key is turned off. Almost all the EFI crap is new including the pump and filter.
It seems like a fuel vaporizing issue. The only thing I have not replaced is the fuel pressure regulator. Any suggesstions?
