60 starting problem (1 Viewer)
East TN
Truck off...battery reads 12.32 Yet no power to lights or anything. Nada. Dead. Therefore it does not start.
When I connect jumper cables from my car, lights will turn on and truck will start and run for a few mins then die. While running the battery reads 13-14. Once it dies, all power is lost again. Yet battery still reads 12+.
If it were alternator issue, would the volts not drop on the battery once it died after running for a few mins?
Is it a voltage regulator issue? Are VR's internal on the 60 alternator?
I am about to pull the alternator and have it tested. Just wanted to see if anyone had any advice or experience this before.
I have never dealt with that problem directly. However, most starting issues I have had in recent years have all been related to the battery. Even when the battery showed a 12+ volts. Before pulling the alternator, I would take the battery for testing. If possible, pull the battery from another vehicle and try starting/running your 60 with the borrowed battery as part of the test.
Sorry not to be of better help.
Finally, when I have a starter or alternator going south; I have them rebuilt at an alternator/starter shop. It may not save me money but I have confidence in the finished product because it started with a core that I know & have experience with.
Good luck. Keep us posted.
could be a defective battery... they can have a bad "cell" and still show 12volts. Get the battery load tested.
Thanks for the replies. I'll have the battery checked first and let you know.
This was a new one for me. In my experience it's always been a dead battery or dead alternator. So when the batt read 12+, I began scratching my head. Then I grabbed the Raid and sprayed the wasp nest that was nicely built behind my gas lid. Ugh...I hate bees/bugs. There were about 30 dead wasps when I opened the lid the next day. Nest number two was being constructed under the tailgate. They didn't survive either.
Battery tested good. Will have alternator tested next. Is local auto parts store sufficient for testing alt.? Or will an alternator specialty shop be better?
If a specialty shop is open today, then I would go there. But a parts store should be able to run a good test too.
We're missing something here. my first thought was also a bad cell in the batt. Are you sure the parts store load tested the batt and didnt simple read the voltage across the terminals (there machine will do both) did u notice a voltage drop at the batt when u turned the lights on? I will be surprised if the alt is the problem ( but it wouldnt be the first time ). I once had a bad batt term cause something like this. when i clamped the jumper cables on it made a better connection,when they where removed the car wouldnt run.
Ridge
off topic... but can you post or email that pic you took of the 60...when I was about to go down the hill sideways...
I've had a battery do something similar and you could not see the issue until the load test..but that's just a guess from where I sit. Might be a defective connection somewhere too.
Check your + cable at both ends. Sounds like a cable issue. Also Check the - cable.
I asked if the battery test was a 'load' test and the answer was yes.
You guys are barking up the right tree with the cable issue. I talked it through with a friend at lunch on Friday and he too insisted it was a cable or terminal (clamping) problem. When I returned home with the battery, I put it back into the truck without connecting it and left it for the night. Friday after work, I put the cables back on and voila, lights...camera...action. It fired right up! There wasn't excessive corrosion on the terminals and everything appeared to be "okay". But I guess there was some kind of buildup preventing a good connection. Thus clamping the jumper cables forced the connection.
I'll cleanup the terminals and posts well and see how it holds up. But for now I think I'm good to go.
Thanks for the help all. Should have been able to solve this one on my own, but these days I get more time on the "keyboard" than "wrenching". So I went straight to the "experts".
Cheers!
