- Thread starter
- #21
Also got the most important part for the set up today.... test fit was a success.
.....I would highly recommend a remflex gasket for the intake/exhaust for your final install. I'll be watching this thread for sure. If I could afford it I'd turbo everything!
Yeah if you have one that would be great I’ll shoot you a message.IIRC I have a manifold gasket at the house I'll let go for cheap.
I've seen guys with 2H turbos do a U shaped adapter and sit the turbo next to the manifold, above the steering shaft. Would that work better?
That internal wastegate actuator is absolutely massive, damn.
I got a small turbo from a JDM spec 2000 Forester. I can take some pics/measurements if you want.
I’ll check that out I might go that way but my plan plan still stands as finding a way to set up a blow through system while retaining a stockish look and from what I see an external what’s gate brings in some more pipe at least more than I want to try and do...Cx racing makes a turbo kit for the 258 jeeps. Maybe you could use their turbo instead and use a external wastegate.
so you may be selling that turbo???
