60 C-Channel Repair Rails (1 Viewer)
TRAIL TAILOR
Enabler
Supporting Vendor
Redding, California
Website
trail-tailor.com
For all of you that need to strengthen that rusty rear frame back up..
3/16" channel reinforcement rails with Grade 8 hardware 190.00 Shipped .. With 18-8 Stainless Steel hardware 200.00 shipped.
These are bare metal and shipped with a 1/2" step bit to assist in the install.
I am trying to locate a 62 frame to get the dimension on the 3 end bolts. all holes line up on a 60/62. The 62 has a few more holes on the vertical face.
Let me know if you have any questions.
Thanks for looking,
Jason
Those are for an FJ62?
I remember you mentioning that you had an FJ62 donor frame on its way so you could produce these for an FJ62, apparently they aren't the same as the FJ60 but I'm not sure how exactly.
Anyways they look great, my 100% Florida frame doesn't need them YET but they are starting to weave a little bit... I'll let you know when the time comes. Not looking forward to that project. Probably better to just swap an 80 frame/coils under!
EDIT Just re-read the your original post.
Double post!!
Triple post!!
If you're thinking about these for your rig They are a great solution! Mine worked out great! Thanks Jason!
Do you still make these steel c - channel reinforce ments?
Reevesci, I have an 87fj, the PO cut out the rear crossmember leaving the diagonal parts riveted on both sides I'm restoring my truck and I don't know how difficult it is to find an OEM replacement. Have you ever had a request to make them? Thanks
