60 / 61 / 62 Series Lock & Key Repair Re-Key & Re-Coding ALL things LOCK SMITH Technical Shop Resource (4 Viewers)
YOU DO NOT do this here below using a giant drill , you will blow sh# t up inside the magnesium receiver ....
you can
ONLY use the RED INK approach i outline , below ............in red ink , this is a procedure best suited to a Professional TOYOTA Lock and Key Technician , and or a certified Licensed lock smith ....fyi
Another key out there that works is 90999-00129. Used on things such as Toyota Dyna, Hiace, etc. Looks similar to the 90999-00212 you can get today but is shorter in length. Basically a different variant of 90999-00104 with a plastic head vs rubber and no “pentagon” shaped key hole. This has been superseded to the -00212 like all other ones.
  • Back
