5 speed transmission into PRADO
North Vancouver
Hello!
Does anybody know if the 5sp. transmission in Prado is the same as the one in Surf (R150f)? Would it be an "easy" swap? I am running auto right now. What other options do I have?
Thanks!
It will work, but you will need the correct transfer case for your LJ78.
There are also a few different shifter location options. You will need the pedal, booster, and master cylinder from a 70 series RHD. Also, don't forget the flywheel, bellhousing, release fork etc.
Do not use the self-destructing flywheel (aka dual mass) if it has one, get a once piece unit.
~John
i have the same questions, what is the correct transfercase? i have a 5 speed from a 4runner, will this work, and tcase is gear driven from same 4runner.
Thanks guys for all your replies! I think I will first look for manual transmission from Prado. If anybody has one, please let me know!
