you need to take a step back and a deep breath......
Conversions don't get done in a week. Not unless you've done a number of them and you're extremely familiar with the subject matter. Even then it'd be challenging.
Sounds like you have at least 3 unrelated issues:
1) o2 sensor codes
2) not shifting into od
3) fuel smell
pick one, do your homework, get it fixed and move onto the next one.
#1 should be simple to figure out by getting the code definitions and working your way thru the alldata procedures as already recommended by others.
#2 we've already discussed. You have to have a working mlps switch that's wired into your harness as discussed.
#3 find the leak. I'd start by looking at the feed and return lines. If they're not leaking then inspect the vapor canister hidden in the passenger rear of the wagon. Pull the interrior panel and see what's going on. There are very few places for a fuel leak. Should be very easy to figure out.
Take a day or two off, clear your mind and then come back to it with a positive approach.
If you've gotten this far, then theres no reason you can't get the job done.
Georg
^^^^^^^^^^^^^^^^^^^wat he said^^^^^^^^^^^^^
