4 speed tranny
Atascadero CA
Ok, well I have a 70' fj40 with a 3 speed and it sucks on the freeway. I am thinking of switching out my tranny to a 4 speed.I just need some thinng that can go on the freeway smoothly. Any ideas, opinions, or advice. If you have any that would be great thanks.
4th in the 4 speed is the same as 3rd in the three speed. Still interested?
Best
Mark A.
DANG! I did not know that. Well I still need some ideas on trannys that will handle the occasional freeway trip. Any ideas
Mark, are you saying that if I put in a SM420 or SM465, 4th gear will feel like my 3rd gear I have with my three speed and will not have any higher freeway speed?
Hang on here...Almost every 4 speed tranny I can think of has the same top gear. Heck, even the 3 speed Cruiser tranny is 1:1 top gear. SM420, SM465, H41, H42, guess what-all 1:1 top gear.
If you want overdrive, there is a hard way and an easy way, The hard way, means a true overdrive tranny like an H55f, or an NP4500. The easy way just involves bigger tires.
My personal opinion, is that only the 4 speed trannies fit well in an FJ40. The 5 speed overdrive trannies are too long to work easily. The drive shaft just gets too short. How fast do you really want to go in a 40?
My 40 has a sm465 with a stock transfer case and 35 inch tires. I can comportable cruise at 55 to 60mph. That's bout it for our type vehicles. I have heard others claim smooth sailing at 70mph. These folks must have differing suspension packages as 60 is about it for me!
Hi All:
Well, no surprise there! A 1970 FJ40 was designed to drive across Africa or Australia at 25mph, not across America at 70mph! :grinpimp:
What are your main complaints about your FJ40 on the freeway? Engine noise? Gearbox whine? Handling? Ride quality? Remember, the basic vehicle was designed in the mid-1950s, and changed in a very evolutionary fashion during its' 26 year production run.
There are things you can do to make a FJ40 more freeway friendly, but only to a limited amount. It will never be as quiet, ride as smooth, or handle as well as a modern vehicle at high speeds.
Good luck! Enjoy the ride! :beer:
Alan
Trollhole got his to go 80 goin down hill on I-20...wasn't fun following him...too much shimmy!
The H55 with a 350 fits pretty nice as far as driveshafts go, but you may find you want to modify the tranny tunnel a bit for more ground clearance. With 35's and a 350, 4 wheel discs and FJ60PS 70mph doesn't feel scary. Don't go jerkin on the wheel and slamming on the brakes though. The vehicle tracks well regardless if it's a good idea. Turns around 3K. Much more comfortable and better gas mileage at 55-60. Do a search on the trannies, lot of $$ that may be better spent elsewhere.
Well there ya go! Least you know it's not necessary to tow it all the away from home.
