Thanks Brian894x4, I have quite a bit of noise coming from my rear now I guess when I can't take it anymore I'll put the 4.56 gears in when rebuilding.
Help needed after reading this thread - I am upgrading to a 33" tire, what is the best gearing for my 94 DD.![]()
No need to regear. Get your tires and drive for a while, if you feel the need to regear at that point, then, you can figure out if you want to be close to stock or go a little further.
Anyhow, barring a repeal of the laws of physics, there's no way you're going to improve MPG by installing shorter gears. Fuel consumption is highly related to RPM and if you turn the engine over an extra 100 times/mile you're using more fuel. Theorizing that the engine is working less hard because it's pushing less hard at a higher RPM is incorrect. Over that same mile with that same vehicle at that same speed, the engine did the exact same amount of work. Work translates into the burning of fuel. However, you added another 100 revolutions, which increased the fuel burn. How? Many ways, but the easiest to explain is that those 100 extra revolutions took whatever amount of power it takes to overcome your engine's friction to accomplish.
DougM
Agree that Toyota had a wide variety of design goals with the LC and also agree that optimal MPG was waaaaay down the list. But will still hold to the point that starting with ratio X from the factory, moving to a taller ratio will generally yield MPG increases/performance decreases and moving to a lower ratio (as is discussed here) will do the opposite.
Also, remember that this discussion assumes that the larger tires are part and parcel of the regear decison being debated. Getting back the MPG lost to larger tires isn't happening.
I think what you allude to is "could there be a better MPG gearing on the totally stock 80 that Toyota could have chosen?" and the answer is almost unequivocally "Yes" because the LC was not optimized for MPG. But I'll guarantee it's in the higher gear ratios than stock, not the lower gear ratios.
DougM
Also, remember that this discussion assumes that the larger tires are part and parcel of the regear decision being debated. Getting back the MPG lost to larger tires isn't happening.
DougM
Most people are going from stock ~31" all season type tires to a 33" (or larger) A/T or MT tire which are generally quite a bit heavier. Unsprung weight, like a tire or wheel, has a much more significant impact to things such as mpg, than the weight alone would lead you to believe.If your theory that higher gears should improve LC mileage, then would it not stand to reason that 33s and 4.11 gears would yield a mileage increase over stock, assuming the LC is otherwise stock weight and height? The weight difference between a 31" tire and 33" tire is nominal assuming they have similar tread width and the affect on the final drive would be like going from 4.11s to 3.86s.
So, with so many Land Cruisers running 33s and 4.11s we should be hearing of rigs getting at least stock mileage if not better, yet we only hear of much worse mileage on all these rigs. I know it's hard to compare when most rigs have a lot of extra weight in armor and gear in addition to the tires and suspension lifts, but I'm sure a number of rigs have run 33s but otherwise nearly stock and yet no reports of decent mileage with this combination.
Gas?
Diesel?
driving conditons? i/e, DD every day highway/ payvment/ low speed driving?
driving style?
I know you say 4.5 but I think theres a diesel 4.5 aswell, dont know.
this is easy calculate the rpm's with 33's then get as close to stock as possable with the avalible gears. (you remamber how it felt w/ stock tyres right?)
they wont be exact so....
With the two ratios +/- your needs or prefrences.
Gas w/automatic, all driving around town and highway.
What are my options?
98% mini guy here just bought an 80.
I'd say 4:56's, with engine enhancements (towing, offroading, minimum) for better milage. (keeps the O.D low but still in the curve, if it's not enough go to 32's it's only a half inch difference)
4:88's if you do any towing or offroading. (your O.D will be a little short/ "Low" the distence bettween cruising rpm and red line)
I will add a gear page, so people can see and blue print there desisions, you need a calculator, the trannies gear ratios, the available gear set ratio's, and the tire sise you plan to run.
Further more these are my opinions. What you deside is not my responsabulity
you asked me I'm tellin you If you aint happy forget trashing me and sell the setup diffs to some one that knows what they want, and go back to what you know.
right on.but the mpg is not drastic.i would not waste my time with 456, go with 488At a higher more RPM the engine might be more efficient and not lugging around.
Note is say “might”
