So I now this topic has been covered a lot. I have spent many hours researching and testing. I could use some more advice.
1998 3.4 4runner LTD 222,000 kms automatic 4x4
I get pending and faults, check engine light comes on. P0300, P0302, & P0305. Misfire in cylinders 2 & 5. These codes happen all the time and have for 3 weeks. Once and only once did I get a pending misfire in cylinder 1. The truck is running extremely lean. An average reading would be 14.7-1, mine is at 28.38-1. I get no other codes. The codes come on at idle and under load.
Replaced with OEM Toyota parts
Spark plugs
Wires
Coil Packs
Injector #2 (had bad resistance)
Engine Coolant Temp Sensor (had bad resistance)
Alternator
Batteries
All Ground and Positive wires
Air filter
Fuel filter
Timing Belt (20,000 kms ago)
Waterpump (20,000 kms ago)
I have had recent and regular maintenance done following the Toyota schedule.
Tested and is okay
Mass Air Flow Sensor
Injectors
Intake Leak
Vacuum Leak
Vacuum Lines
Coil packs swapped around
Crankshaft Timing Pulley Bolt
Injector cleaner through a full tank of gas
Cleaned MAF
When it misfires, I can barely feel it. The truck runs pretty good now, it shifts better and is much more responsive. Under load I can feel a very little lack of power. It is still throwing the same codes. It constantly does it. Anyone else have some advice?
Spark plugs
Wires
Coil Packs
Alternator
Batteries
Air filter
Fuel filter
Tested and is okay
Injectors
Intake Leak
Vacuum Leak
Vacuum Lines
Cleaned MAF
