I'm posting the question here (rather than the 80-series forum) because its a 3FE question.
I have a 92 FJ80 with about 198k.
The engine developed a sudden engine knock so I home. Oil pressure was good.
After I got it home, I ran a compression test and found the following:
#1 - 130
#2 - 40
#3 - 130
#4 - 140
#5 - 145
#6 - 145
I just finished pulling the head and found that the #2 piston cracked around one edge and the debris from the piston was fused into the top of the piston and was apparently hitting
the bottom of the head. There is very slight vertical scratch in the #2 wall (just barely able to catch with a fingernail). Obviously the head needs to be shaved.
a very bad picture - its good enough to get the idea
All the other pistons look good. There is only a slight ridge at the top of the cylinders if any at all.
What would you do in this situation? Is this worth attempting to fix? (ie; throw in a new set of pistons and rings, head job, etc)
Or would that be a waste of time and I should be looking for another 3fe (with unknown condition)?
I wish I had the funds for a rebuild but that's not in the budget.
Thanks.
Steve
#1 - 130
#2 - 40
#3 - 130
#4 - 140
#5 - 145
#6 - 145
Thanks.
Steve
