Wanted 3FE Engine
I have a 3fe from a fj62 I believe it's the same. located in VA. heading to NC on Tuesday could figure out a meet up maybe.
the main block is the same, some bits and pieces will need to be swapped over from the 80 series to make the 62 series engine work in the 80 series.
A lot of external parts are different. Accessory mounting, bellhousing adapter, oil pan, all the sensors, etc, but the block and heads are interchangeable.
