smcruisin said:(like cruiser_guy said),
If you bolt a PS pump&bracket to a 3B with an older (non-PS) alternator, you won't be able to hook up the STOCK alt./fan belt. The reason is, the alternator gets swung on its mount further to the right side of the engine to make room for the PS bracket & pump, rendering the stock belt too short.
HOWEVER, you can retain the stock alternator and still make everything work by;
- removing the stock 'tension bar' (the curved bar that you use to hold the alternator once you've tightened the belt.
- swinging the stock alternator outboard (further away from the engine).
- modifying the temperature sensor wiring at the thermostat housing (so it doesn't hit the PS pump bracket.
- swapping the upper half of the thermostat housing for one that faces the front-left corner of the truck (I'll figure out & post which models/years later)
- bolting the PS bracket to the block (you'll have to remove the engine-lifting loop & a coolant hose support).
- installing the new 'tension bar' (mine came with the PS parts -- it mounts to the PS pump).
- getting a longer belt from the parts-store (I'll post up a part number & length later this evening)
Then comes the fun of running PS lines....
Cheers,
Steve
