3B glow plug not staying on
kling-on
Kool Arrow
Pimpin part in SanAntonio TX
Website
www.texas4x4.org
ok so I have a 1984 BJ60 from Canada... the glow relay clicks on and off in he same second it starts .... the glow plugs get power with a test light and turn off... so I need to figure out what to Ck or replace nexted ... it's really slow to start and I'm sure it's the lack of glow ... any help would be great
Sounds like your timer or relay has gone out. Theres some good threads here about installing a Wilson Switch or you can hardwire it with a momentary switch like on a tractor.
Appears to be common.
Glad my recent import had an aftermarket switch already installed.
Try cycling a few times.
My BJ60 was doing the same thing. Then i realized whatthe silver button was for.
Be sure to pull your GPs amd inspect the resistamce.
Glow plugs are new ... man that timer is pricy I can hear it click on and off anyone know the wire color to Wilson convert the relay
Ok after probing everything this is the solenoid that powers the glow plugs ... black is ground other wire get 12 volts to convert to a Wilson switch ... super easy after found out witch of 3 solenoids there feed it ... for the nexted guy looking for which one it is
