Some folks have asked to post results with my lift/tire combo.
I went up to Tellico yesterday for the river cleanup and went up 5, 6, 4, and part of 3 hauling trash and following Tellico Rob's stinky diesel 40 with a trailer attached to it.
We got a TON of trash and met a load of Jeep, Trout, and Hiking folks...the ATV "cockroaches" scurried all over and didn't do a thing
Anyway, I got to test the new Iroks, lift, etc. and I was very impressed. I aired down to 17 lbs on all 4 and the bulge was not nearly as bad as the MTRs at the same pressure. I was able to idle, and I mean idle over most things in the way. The Iroks gripped like no other tire I have run (ATs, MTs, Swampers, etc). I spun a tire 3 times all day. I rubbed the diff in the front 1 time, and never used my sliders except to pivot on a rock while I was checking my clearance
Now, the fitment is amazing. I rubbed VERY slightly on the custom exhaust run, but no other rubbing aside from a mild touch on the frame in the rear on one side (I still have to adjust the panhards post lift).
I have some detailed pics from the ride, but they are on my sister's camera. Once I get them from her I will update this thread with some poser shots
So, conclusion:
If you wheel in the eastern and midwestern US, have a truck that you drive to the trail, and want the maximum traction, carcass height, and toughness in a really agressive offroad tire...Iroks are the bee's knees!
UPDATE:
Here are some pics:
Running Gear:
Rocks!
Most take a line around this...
Flex n Stuff:
I only did one wheel stand all day, very controlled and stable, and never lifted a tire otherwise...great result.
So, conclusion:
UPDATE:
Here are some pics:
Running Gear:
Rocks!
Flex n Stuff:
