33x10.5x15 BFG AT Pressure Question
Reno, NV
Hey All,
Just put some brand spanking new BFG AT KO2's on my truck. Big fan of the tire but my last set didn't wear so great. I want to protect my investment in these things by running the ideal pressure. i spent the last 30 minutes doing doing the chalk test and my results indicate the ideal pressure should be around 25-26 psi.
I know everyone's truck is different in terms of weight and such but I'm wondering if this is similar to what other guys are running? Seems on the low side to me for every day street use. What's the consensus?
Thanks in advance.
-Ed
I run around 32lbs in mine, pretty much on all my cruisers, 40s, 45,s 60's
Too much air, the 60 handle/track to quick and can ride rough. To little it will corner funky and again not track the way I like. So I run them till they feel right, but long life has never been my mail goal. Just took off a 12 year old set, but 15,000 on them, replaced with new, moved the old ones to a 45, where they may get another 5k in 10 years. Heck I still have 2 rigs with 33x9.5's ;)
26 psi is much too low for freeway driving. I'd say 32 psi is minimum.
Take a look at the sidewall flex of new trucks. They probably have their tires set to spec. Aim for that amount of sidewall bulge.
I ran mine at 35-38psi on highway (stock rims). Perfect wear and no issues.
J
Thanks for the feedback guys. Kind of baffled why my chalk test came up with such a low PSI.
Decided to air up to 36 psi and ran some errands in town today including some freeway miles. Felt good - love the feeling of new tires under the rig. :smokin: May drop the psi a bit later, we'll see.
:cheers:
-Ed
@cruiser enthuiser
I have similar experience. Was previously running 33x10.5x15 AT's on 8" wheel. 35psi seemed to be the number. Tires wore terribly in the center of the tread. This was consistent in all 4 tires so it wasn't a rotation issue.
Bought a used set of KM2's with minimal miles on them. Same size, same wheels. I got them swapped at a friend's shop. He followed the method of looking at the max load of the tire at a certain PSI. My FJ60 is not that heavy, he recommended 25 PSI. That was ~4 years ago. Tires are wearing evenly.
Now if I know I'm doing some highway miles, I'll bump up to 30 PSI. Makes a huge difference in economy.
So as we can all see, it really just depends on the weight of the vehicle.
Good thread. HTH :cheers:
I was shown this chart by my tire guy. It is from 4WheelParts site, and has worked well on all our vehicles. This gives a calculation, instead of a guess...
In my case, loaded with full fuel, our 60 weighs around 6200. The tires are 33X10.50X15C BFG KM2's that carry 2600 lbs @ 50 psi. This equals 52 pounds per psi. So 6200 / 4 = 1550 lbs / 52 lbs = 29.8 psi + 10% = 32 - 33 psi running pressure.
If the 60 light/empty, I reduce the pressure to around 26 psi.
This has worked very well on my 60 and the tires wear is good and regular.
I use the same calculation on our motor home, trailers and cars.
Tire Pressure Checker: Righting the Pressure in Your New Tires
The excitement of getting new tires can leave you giddy in the short term. But, if you expect those new tires to keep making you happy over the long haul, you’ll need to address some practical concerns before it’s too late.
Once you upgrade your tires, the first objective is identifying the correct tire pressure for street driving. To determine the ideal tire pressure for a stock truck, your best resources are the tire inflation placard and the owner’s manual. Unfortunately, these resources don’t help you when you don’t have stock or close-to-stock tires on your truck. Once you put bigger tires on your rig, it’s a whole different ballgame.
Let’s start with two simple ideas. One, the load of your truck is supported by the air volume in the tires. The constant is how many cubic feet of air can hold up a specific weight. What isn’t constant is the size of the container holding the air. Say you have two containers of different sizes holding the same volume of air. In this scenario, the smaller container will have higher pressure than the larger container. That means the larger tire needs less pressure than a smaller tire to carry the same vehicle weight. What many truck owners don’t know is how much less pressure is required. You can calculate this difference using one of four methods.
  1. Let the sidewall tell you
    This is the easy, guesswork method, and provides an immediate answer to your question. Find the maximum pressure as shown on your sidewall and let that be your street pressure. It will suffice until you have time to make a more accurate calculation. Note that this usually means your tire pressure will be too high, particularly if the truck is not carrying a load. This is because the maximum air pressure is the right number when the truck is fully loaded. The sidewall should also tell you the load capacity at the maximum tire pressure. That capacity can likely support half your truck’s weight, or more.
    The advantage of using this maximum pressure is that it’s safe. You may even get a fuel economy benefit out of it, because your rolling resistance will be minimized.
    The disadvantages are related to ride quality, handling, and uneven tread wear. At maximum pressure, you’ll feel every bump in the road. The contact patch will be concentrated in the center of the tire, which impacts the responsiveness of your steering and brakes. You may see faster tread wear in the middle of the tire.
  2. Let the vehicle weight tell you
    The tire maker defines the ideal tire pressure for loads of various sizes. You can get the chart for your tire from your tire maker, a tire shop, or online. A less accurate alternative would be a generic chart from the Tire and Rim Association. These recommendations are available in the most popular sizes, but the stated pressures are not specific to your tire.
    Weighing your truck. The next step is to obtain the front and rear weight of your truck. Do not estimate or assume that your loaded truck weighs the same as it did when it rolled off the lot. You’ll get a more accurate result by packing your equipment onto the truck, filling the gas tanks, and even inviting some passengers to come with you to the scales.
    Scales are typically available at scrap yards, recycling centers, landfills, and, of course, truck stops. You need to determine the amount of weight on your front tires, and then, separately, the amount of weight on your rear tires. If there’s a race shop near you, you may be able to use its portable scales to get these weights quickly.
    At a truck stop, you’ll have to take three different weights. First, drive up and stop when only the front tires are on the scale. Record the weight. Next, drive your truck forward until all tires are on the scales. Take another reading. Lastly, drive off the scales so that only your rear tires are being weighed. If you’ve done it right, the sum of the front and rear tire readings should be roughly equal to the total truck weight. You may learn that your truck carries more weight on the front than on the rear. This isn’t that uncommon with pickups.
    Next, divide the weight on your front tires by two to get the weight on each tire. Do the same with your rear tire weight.
    Finally, consult your load/inflation chart again. Round the calculated weight up to the nearest tire pressure and add another 10%.
    Check your results. To check your results, you can measure the tires and add pressure to balance them. Before you measure, make sure your truck is parked on flat ground. Then, along the centerline, measure the distance between the ground and the edge of the wheel on all four tires. As noted, if there are differences, add pressure to even things out. The profiles should be almost the same from front to rear.
    The advantage of this method is that you should end up with the optimal pressure. Optimal means you are balancing fuel efficiency, the quality of your ride, handling and braking performance, and uniformity of tread wear.
    This disadvantage of this method is that it’s tedious and could give you the wrong answer if you weigh or calculate incorrectly.
  3. Let the chart tell you
    If your truck has not been substantially modified, outside of the larger tires, you can use your tire inflation placard and a load inflation chart to identify a tire pressure.
    The first step is to find the chart that goes with your stock tires. Locate the pressure that relates to the recommended pressure on the tire inflation placard. Then, look for the weight the tire should bear at that level of pressure. Next, get the chart for your new tires. Look for the same weight there. If that specific weight isn’t listed, select the next highest weight and record the recommended pressure.
    Let’s go through an example, using a 2005 F-150HD that originally had 245/70R x 17D Load Range D tires.
    • According to the tire placard, at maximum load, the tire pressure should be 50 psi in the front and 60 psi in the back.
    • When you locate that tire at those pressures on the load inflation chart, the rated loads are 2,205 lbs. and 2,469 lbs.
    • The proposed new tires are 285/70R x 17D Mickey Thompson MTX Load Range D tires. The closest numbers on the load inflation chart for those tires is 2,340 lbs. and 2,540 lbs. These equate to 40 psi and 45 psi, respectively.
    If you need to adjust for differences in the pressure or weight between the charts, you can do it using this formula:
    • Tire weight/tire pressure = Load capacity pounds per psi
    You would start with the load and pressure closest to the original tire, adding or subtracting to find the proper adjusted pressure. In this example, the calculation would be:
    • Original tire: 2,205/50 = 44.1 pounds per psi
    • New tire: 2,130/35 = 60.8 pounds per psi
    To determine how much tire pressure to add, subtract the weight of the new tire at pressure from the weight of the old tire at pressure. In our example, this results in 75, or 2,205 minus 2,130. Next, take that result and divide it by the pounds per psi of the new tire. This equates to 1.23, or 75 divided 60.8. Adding the 1.23 psi to our front tires would amount to 36.23 psi, which we rounded up to 37.
    For the rear tires, the old tire had a slightly lower capacity than the new one. In this case, you could go with the 45 psi or let out some air to reach 43.6 psi.
  4. Let the chalk tell you
    You can also “calculate” your tire pressure with the chalk method. This involves coloring a section of your tire with chalk to see how much tread is making contact with the ground. Start by finding a flat road surface. Concrete is actually the best choice, but you can also do this on asphalt. Make a mark with soft chalk that goes all the way across your tread. Then, gradually drive your truck forward about 50 feet and then backwards 50 feet.
    Analyze the chalk on the tire. If the chalk is only worn off on the center of the tire, reduce the tire pressure slightly and go through the process again. With the adjustment, you should see the chalk wear off more broadly. Keep making tiny adjustments in the tire pressure until the chalk wears off evenly and all the way across the tread.
    You will have to complete this process for each of your four tires. Once you’ve found the right street pressure, add 10% to all four tires. Then, measure the tires and add pressure to balance them. As explained above, you need to measure from the wheel to the ground. Start by balancing the profiles of the front tires with each other. Then, balance the front tires again with the rear tires. Always adjust the tires with the smaller profiles by adding air.
    The advantages and disadvantages of this method are the same as those involved in the second method above. If you go through the process correctly, you end up with the ideal tire pressure. But, this method is tedious and there’s a reasonable chance that you will make a mistake.
Testing your tire pressure
You should always test out the results of your tire pressure calculations with a heat test. If tires are under-inflated, unnecessary friction and rolling resistance will result. Those conditions generate heat. Manufacturers use tread pyrometers to test tire heat, but this can also be done by measuring the change in tire pressure. Note that this test is mainly for preventing under-inflation.
Do this test on a day that’s warm, but not hot. Ideally, the outside temperature should be mid-70s to low-80s. To set up the test, locate a relatively straight section of highway that’s 13 or 14 miles long. You want to drive at 55 mph, or the maximum speed limit, for about 10 or 15 minutes. The tires should be at resting temperature, so you may need to stop and relax in the shade somewhere to let the tires cool before you begin.
The first step is to measure the tire pressure of your cool tires. Then, hop on the highway and drive at the maximum speed limit for at least 10 minutes. Pull over safely and take another reading of your tire pressure. If the tire pressure has risen less than 10 percent, then you are done. Your tire pressure passed the heat test.
If the tire pressure has risen more than 10 percent, there is more work to be done. This is because a rise in tire pressure indicates a corresponding rise in temperature. For every 10 degrees Fahrenheit, the pressure will rise about 1 psi. In other words, a 10-psi increase equates to a 100-degree temperature change.
A compressor will come in handy here, so you can add air pressure immediately and run your test again. Start by adding a few pounds of pressure to each tire that demonstrated a large pressure change. Then, let the tires cool and take another 10-minute drive.
Note that tires with aggressive tread patterns tend to run somewhat hotter at the ideal pressure relative to street tires. This conclusion is based on observation and experience only, and there’s no conversion formula to quantify this difference. Just make a mental note that if you are driving on mud-terrain tires, they may generate more heat than a tire with a milder tread pattern would.
Once you complete this test, you should also drive the vehicle and pay attention to the handling, particularly around corners. Let your subjective judgment tell you whether the tire pressure is appropriate or not.
Adjusting for loads
You can use the methods described above for any load state. Just remember that if you add or remove weight from your vehicle after testing, the tire pressure will need to be retested as well. You could complete these tests again every time you change the load, but this will obviously be time-consuming. Many truck owners prefer a less exact approach. They will inflate the tires to max load when the rig is fully loaded, and then let out air for unloaded driving.
Pressure changes over time
Most tires drop about 1 psi of pressure monthly. Changing seasons will also reduce tire pressure, usually at the rate of 1 psi per 10 degrees of temperature change. For example, a tire that reads 31 psi at 30 degrees might read 35 psi at 70 degrees. The only way to address these changes is to check your tire pressure often and at regular intervals. You will be rewarded for your efforts with better fuel economy and more even tread wear.
One last note
The last three methods described above require patience and attention to detail. If you can’t dedicate your focus to the process, then use the max pressure noted on the sidewall.
Doesn't it say 26 or 27 PSI on the door jam as the recommended pressure?
IIRC the placard calls for 32 PSI. But, with the drivetrain mods, lift, much larger than stock tires I don't think this number is relevant any longer.
Adjusting for loads
One last note
Doug, thanks for posting. This is exactly the source of information I followed when conducting my chalk test. I was a little unclear why this site said to add 10% when none of the other sources I read recommended this.
There's obviously a lot of variables at play here and perhaps no one right answer.
Cheers!
-Ed
