33" tires and winch on LJ71
crushers
post ho
Derwent Alberta
so my helper wants to come to the river shiver 2005 but does not have a vehicle to drive. i have a LJ71 that i have wanted to try some new ideas on.
first is the 33" skinnies and then a low profile winch and mount.
the 33s bolted on with ease and NO lift and after some extensive testing found they do not rub even under full articulation. another interesting side note is that the truck turns these tires with no problem at all. in low range other than a lack of traction it is almost unstoppable. it has wicked approach and break over angles and if the rear bumper was removed it would have great departure angles as well.
side hill is fine but the truck does feel top heavy in comparrison to the Mits J54 and the flex isn't as good either but i think if i was to cut the stoppers down a bit it will make a noticable difference.
the winch plate is a custom above the frame mount and the approach angle has not been hampered in any way. the tuggem points are the problem, they hang way too low so i will need to address this in the future.
here are a couple poor shots of the winch and the flex:
I love my tall skinny's I must have 3-5 sets of them.
tomorrow i find out which performs better, i have the 33s on the lj71 and the 35 fat ATS on the HZJ75. both will be doing the same trail so this will be interesting... well at least to me it will be...
cheers
Wayne,
Looks cool, and I also have been saying that bluey is pretty unstoppable with 3.70's and 35" and they rarely rub so I am not surprised either.
good luck at river shiver, I wish I was there, but I am in spirit, I am in Buffalo New York so I can appreciate the colder weather :)
cheers,
Michael
