315-75-16 winter tires (2 Viewers)
Vancouver BC
So, what's the best? I'm thinking about studded duratrac but are they actually snow tires? What about the Yokohama I/T?
For urban and highway use, and occasional deep snow if/when I go snow wheeling. But I'll be packing chains when I do that.
So, what's the best? I'm thinking about studded duratrac but are they actually snow tires? What about the Yokohama I/T? For urban and highway use, and occasional deep snow if/when I go snow wheeling. But I'll be packing chains when I do that.
Yes they are snow rated tires.....
"Wrangler DuraTrac light truck tires are branded with the mountain/snowflake symbol to identify they meet industry severe snow service standards. Wrangler DuraTrac tires are designed to accept optional #16 metal studs to enhance ice traction."
If you wanna read the full explanation.....
What's the difference in snow traction between an M+S (Mud and Snow) branded tire, an all-season tire and a purpose-built winter/snow tire? While many drivers probably aren't absolutely sure, it can be the difference between getting to work, getting home or getting stuck.
The original definition of M+S tires is based on the geometry of the tread design. The M+S designation was first used to differentiate the knobby, bias ply tires intended for use on muddy and/or snow-covered roads from the straight rib tires used on early cars or trucks. Tires with tread designs that meet the definition may be branded with the letters "M" and "S" in several different ways (e.g., M&S, M+S, M/S, MS, etc.) at the discretion of the tire manufacturer.
When early radial ply tires were also found to deliver more snow traction than the straight rib, bias ply tires, the tire companies introduced all-season tires. Supported by advertising, all-season tires have presented an unspoken promise that they, throughout their life, can provide traction for all seasons...through spring's rain, summer's heat, fall's cooling and winter's snow. While this combined offering has made all-season tires popular, many drivers have learned that a geometric definition doesn't guarantee winter snow and ice traction.
In 1999, The U.S. Rubber Manufacturers Association (RMA) and the Rubber Association of Canada (RAC) agreed on a performance based standard to identify passenger and light truck tires that attain a traction index equal to, or greater than 110 (compared to a reference tire which is rated 100) during the specified American Society for Testing and Materials traction tests on packed snow. The new standard helps ensure that drivers can easily identify tires that provide a higher level of snow traction.
A mountain/snowflake symbol branded on the tire's sidewall identifies tires that met the required performance in snow testing. The mountain/snowflake symbol is expected to be fully implemented on new tires by now, however there still may be a few winter/snow tires in the marketplace that meet the requirements but were produced in molds manufactured before the symbol was developed.
"Urban and highway use and occasional deep snow"....if that is the case why get them studded?? It sounds like the "non-studded" version would work for your needs. I have duratracs on 2 vehicle in live in ND. They don't salt roads, don't plow many of them and it is windy (drifts everywhere). I would pass on studs....
I use General A/T Grabbers and they have the snowflake/mountain symbol. I like them and they're not too expensive.
Yes, but so are the BFG AT which, IMO, is a horrible snow tire. Any of the snow specific car tires will kick the butt of a BFG AT. Of course, the AT isn't studdable either...
Fwiw I'm running BFG KM/2 and think they're awesome on the freeway and off pavement in the rocks and dirt. Just not happy with them on snow and ice. Although chains do make a big difference.
I have some spare rims, so will mount a set of winters. Planning on studs, since they're not expensive to have installed.
My wife and I have no problems driving in snow/ice in our Duratracs. Great tires and wish they made 'em in 37's.
I use Duratracs year round on my trucks, they are great on snow & ice, no studs in mine either.
Vote for Yoko's. Having had DT's for 2 winters, they're definitely not on par with a dedicated snow tire.
With the chinooks we we get , it can go from 2' of fresh to nothing in 2 days, with ice in between. Studded tires plain suck on asphalt. The Yoko's are quiet as they use walnut shells as studs.
I'll be buying 315 Yoko's next. Nokian's come in 315's as well.
Have fun in the pow!
+1 for the Yoko's. Having only run them and not the DT's, I would suspect that the Goodyears would do better in sloppy, wet snow, due to the lug spacing. If you studded them they would probably do better in ice.
The Yoko's will do better in all other snow circumstances. The lug spacing i have noticed is a bit tight, but they do great on packed snow, and have a very soft rubber.
I put a few thoughts into this thread: https://forum.ih8mud.com/tire-wheel-tech/348421-yokohama-geolandar-i-t-thoughts-review-ish.html
Had my Duratrac's for 3 winters and they have been fantastic, I run them all year round but in the snow they are great. I too have run BFG AT's in compact snow and ice and would never drive a car with them again.
With the snow you and I see here I would have no issues with the Duratrac's. I have run in the winter up the Coke and the Merritt/Kelowna connector in white outs and never had any traction issues with the Duratrac's in those conditions. They are good when aired down in deep snow as well, turn into big pillows with good grip.
I have Duratracs on mine too in that size and they are great in the snow and ice that we get in Illinois. I live in the country and we get lots of drifting. It does great through that and on the slick roads. Great year around tire.
Other than the clicky clacky noise of the studs on asphalt, what makes them suck? I had one set of studded snowys, didn't hate them, but that was on an old Volvo.
Guessing the Volvo wasn't on 315's. That's a lot of studs....255's may be better option, if your set on studs?
If your going for float - 37's min.
Other than the noise, when you're on clean asphalt, your contact patch is reduced to a number of pinheads, even on a wide 315 tire, you'd be further ahead with an all season tire in clean road - winter driving conditions.
I would say if these are just going to be a dedicated winter tire look at Nokian, I have had a few sets and they are incredible in the snow/ice/compacted ice snow we get here all to often. I never had them studded and never felt I needed it.
For an on road snow tire why not look at something like a 235/85 its tall and skinny and I have found that is the ticket with road going snow tires. If you are looking for a deep snow off road tire you need one that will big like a snowshoe when aired down and 37+. Unfortunately the two uses require tires that are polar opposites.
