To each his own I suppose, I love mine and every time I'm on the trail or the the streets I don't regret it at all. The only thing I need to fix is raising my roll axis by raising my trac bar but other than that feels extremely stable
Yup agreed. I personally see no problem with the stock set up.To each his own I suppose, I love mine and every time I'm on the trail or the the streets I don't regret it at all. The only thing I need to fix is raising my roll axis by raising my trac bar but other than that feels extremely stable
Well I am...![]()
How does the coil remain seated on the depicted rigs?
You would definitely need limit straps whether you had CO's or not
Capture the springs at both ends. It greatly reduces the tendency for the body to unload. I also run a limit strap in the center of both axles.
My 3 linked rig flexes and climbs better than my 80, with better clearance. I run 80 series bushings for rod ends and they have held up very well for 4 years.
It does not drive on the street so I have no input there.
Very short upper and long lower = brake dive. That suspension is not designed properly.
Poor mans 3 link? Hitch pin mod?Hey Douglas. Just to clear this up for anyone following. Only the left side dived down. As the tower was not centred. It was off to the right. It's kinda the same as removing 1 of your front bolts.
Why do you feel like anyone in a thread specifically about building three link suspensions cares that you prefer the stock setup?
Wheeling an 80 with the stock front suspension links is like wheeling an IFS truck. There are massive gains to be made in the front suspension, lockers don't make up for as much as some would have you believe.
I'd wait for socal to finish his housings.
You will have to ask him directly.
Jealousy will get you nowhere. LOL.Because he has a "hardcore rock crawling 80"! That will go anywhere a 3 link can.
