Good morning mud,
'99 LX470 with 301,000 miles. OEM starter.
I've read a lot of posts about starter issues on the 2UZ-FE, and every post talks about a starter working intermittently, or clicking noises and the starter not working at all. None of these symptoms match mine.
My starter turns the engine over and it starts every time. I will say it sounds like it's taking the starter a few more revolutions before the engine starts. Right when the engine starts and the starter is disengaging the crank, I hear a whining noise. Sounds like a slipping belt, or a slipping clutch (similar to a failing AC clutch). I've confirmed this is not my serpentine belt, and the noise is clearly coming from the back of the engine where the starter is located. I have a 6 month old Optima Red Top battery that is sitting at 12.5 volts at start up so I don't think it's a battery issue. The noise after the engine start up is leading me to believe it's the starter.
Is this a sign of a failing starter? Is there a clutch in there that fails at some point? Is there anyway to confirm or do i just need to keep driving it until the symptoms really show? Any help is much appreciated. I have a road trip up to the OBX in a week and don't want to be stranded on the sand with a dead starter. If I need to proactively replace it, i'll do it this weekend.
Thanks,
Eliot
Thanks,
Eliot
