Anyone supplying there turbo oil from the vacuum pump supply line? was thinking of getting a double banjo bolt and picking up from there, it appears to come from the camshaft bearing supply, I noticed the 12HT has a fitting a bit above the vacuum pump supply line....was thinking it might save me some mucking around running over to the other side of the engine via the pressure sender, Thoughts?
Gareth
Gareth
