- Thread starter
- #21
So now, I'm going to extend the glow plug wires into the cab of the truck and put a big ass switch under the dash, so if the glow plugs go into runaway again, I can shut them down within Coldtaco's 8 seconds ...
asked when I'd be coming to bed. I said in an hour. Thread revival - I have an '84 BJ60 and I'm also dealing with constant voltage at the busbar. Just replaced the secondary relaying thinking it was the culprit as I get a constant 5V but that didn't solve it, but reading this thread has got me thinking its been the main all along. Have you had anymore issues or had to replace your main relay? I'm about to go give my main relay a good wack and a little wiggleI haven't been able to get the relay open- though think the way the studs work is probably similar to the Warn relay in your photo above. My relay has been working fine since I wiggled the power studs and then left the nuts a bit loose. I didn't want to pound on it too much, especially after it started working again. I did hit it hard enough that if it's a simple press fit, it should have come apart- I'm really not sure how it's held together.
