Hey guys,
Been a bit quite on the engine front, i have just been squirreled away in the shed late into the evening cleaning. The machinist finally got back to me on Monday...the verdict.
Head is OK - no cracks, all valves are ok
Block will be taken to 40 thou oversize. Total damage should be between $700-800 bucks for a reconditioned head, bored, honed and faced block. Seems pretty good to me, but im no expert in these things. I am budgeting more like $1000 for the work...
I have ordered all the parts to fit the engine from engines Australia....parts are
- New rocker arms x 12
- New pistons & rings with alfin inserts and pins/bushes
- All bearings and seals
- Full welch plug kit
- New glow plugs
- New valve lifters
- New valve seals
- New valve guides
- New pre combustion chamber
Total was around $1270. Very happy with the service/advice these guys have offered, supposedly it will turn up tomorrow (overnight delivery) which would be awesome!
So, i should have my block back mid/late next week, will drop in my crank as it needs a speedy sleeve on the output oil seal surface.
Fuel pump will be going to the re builders, which should be around $1000 for pump and injectors.
That leaves me at around $3270, which will probably be more like $3.5 once i get some coolant, oil, filters belts etc.....
Im hoping to setup a time lapse video of the re-construction, i will put some pics up once i have the block back!
Cheers
Frosty
