2H low oil pressure issues momentarily drop when cold start
Turkey
Hi,
My HJ60 get a strange habit last 3-4 days. When i started engine in the mornings, oil pressure increases and then momentarily drops low and fluctuate there and then increase again. After driving a while and engine reaches the operating temperature, everything returns to the normal. In the event of drop, edic does not stop the engine. Oil level is full and i changed the oil approximately 4K km ago with a new filter. I uses mobile 15w-40 oil in my rig. And lastly mornings are not actually cold, about 8-9C.
Do you know or do you see such a behavior before ? and why ?
Thanks for your helps in advance,
Thanks for the reply. I don’t think the sender is a problem, but i will measure it. Regulator valve could be the issue however there is neither constant high pressure nor constant low pressure. After couple of minutes later everything returns normal.
