2F to 3B conversion advises needed
Hello all mech. and Tech. Gurus, i need your advises about an engine swap from 2F to 3B; current engine is a 2F, transmission is a H41 with 19 splines i think as the truck is dated 1984 all stock/factory.
So beside the engine here it is a list of the modifications that i should have to realize:
Belly Housing
Cross member
Engine mounts
and finally input shaft for B engines.
I can deal with the first 3 but the 4 th one is a major problem to me;
as far as i know i can not use an input shaft from a H42 on my H41 tranny + the donnor is a Bj60 86 or 87 not sure of that then the tranny has to be H42; i can not have the whole drive line, wrecker has already sold the transmission as a chunk, all i can have is the engine belly and may be the cross member.
Can you help me out?
how can i connect this engine to my H41 without searching for a H42 tranny?
I appreaciate any advise, idea, help...Thanks
Cmon guys at least you can tell me whether the input shaft from H42 is interchangeable with H41's input shaft or not?
Or can i use the B type input shaft of a H41 with the H42 spec. 3B engine?
Someone must have the answers...
You need to be posting diesel questions in the diesel forum. :doh:
No, the input shafts are different.
Move this to the diesel section and detailed answers will appear like magic.
~John
